11861 - 11868 of 11868 Posts
Hi,
I have a Dune D1 and problem with remote control commands.
When I activate Dune via the on / off button, I can connect using the remote control power on command.
But, from that moment, no command is recognized, not even disconnect with power off.
I found out that I can use the app on my smartphone, as Dune receives an IP, and that's how I'm currently using it.
But I would like to return to using the remote control normally.
Does anyone know what may be happening?
I have tried several versions of firmware and nothing has changed.
Sorry for my English, but I'm Brazilian and I used Translator.
Tks.
@Mamasboy
Adding codecs to a player might be done via firm update by the manufacturer if the hardware is capable handling those codecs.
Since Dune moved to new devices you need to move on also.
Or try playing files the player can handle.
I do the latter with my Max
Sent from my HUAWEI NXT-L29 using Tapatalk
@Mamasboy
I guess when it gets bad enough I'll move on to the Nvidia Shield.
Can anyone help me figure out how to scrape NFL games? TVDB & IMDB seem useless.
I would just put them in a folder and name them properly so you know what game is what and go to them directly. If you wanted in zappitti with pretty photos you would mostly have to do it manually which might not be too bad for a game here and there.
Thanks for your response. I'd like to have them in Zappiti, and was hoping that someone had figured out a naming converntion that will allow them to be added. I have them organized by folder now, and that works, but I'd like to do better.
I would use any movie name for the game file to scrape that pulls in some pictures to Zappiti. Then take photos you downloaded to your PC that properly ID the game and use them to update the movie auto scraped photos for the thumbnail, background, etc... Then hit the edit button and change the title, synopsis, cast (the main players), and directors (coaches) Should be fairly simple.
