1 - 20 of 20 Posts
My humble setup:
Cable management really was a challenge since the walls are all concrete.
Update 3/31/2012
samsung PN59D550
Yamaha RX-V1800
samsung BD-E5900
Xbox360
Yamaha NS series:
NS-555
NS-C444
NS-333
YST-SW315
Nice HT, very clean.
Super clean look, Simple and elegant well done.
Originally Posted by SAVholic /forum/post/0
My humble setup:
samsung PN59D550
Yamaha RX-V1800
samsung BD-E5900
Xbox360
Yamaha NS series:
NS-555
NS-C444
NS-333
YST-SW315
I like it, we have similar tastes!
Now that's clean! Have you tried angling your rears a little more towards the mlp?
Discussion Starter · #6 ·
Thanks for the reply!
The next step is to add a black/white(finally convince the wife) rug and maybe some accent pillows.
Discussion Starter · #7 ·
I move them a couple of inches, It looks almost the same but they are more directional from were we sit. thanks for the input!
Banned
I like the cabinet with shiny sheen gloss look and front wall orange or is that terracotta? I like the floor clean look do you use a mop or vacuum cleaner or a little bit of both?
Clean simple all-around homey place you have.
Very organized and well done setup. That looks like the same color of paint I used in my theater.
Discussion Starter · #11 ·
Thanks! I looked at your setup as well, very nice!!
The color is actually "chili pepper". We use a mop and then a dry mop so the tile is streak free. I'll try to post some pics after we add the rug.
Originally Posted by Rodrigues_Brazil /forum/post/21837818
Great yamy setup and your room is clean and beautiful, congrats!
Thank you! The speakers really deliver a clean and transparent sound.
Discussion Starter · #12 ·
Updated the first post. Added the rug today
Super nice clean setup. Area rug is awesome. The color really ties everything together. Is it comfortable to walk barefoot on? Where did you buy your area rug??
Discussion Starter · #15 ·
Thanks! and yes the rug is very comfy to walk barefoot and I got it at a local furniture store called "Paos"
Originally Posted by jproy13 /forum/post/21955199
Very nice and clean. Always had a soft spot of the NS, I think they look great.
Nice camera work too
cheers
Thanks!... the next step is to replace the sub with a gloss black SB12-NSD or dual SB12's
Very clean!! I need to know how you hid the wires!? Did you try the Ns-333 as mains? Impressions?
Discussion Starter · #17 ·
Thank you! Well for the wires, I had my contractor put a 2" PVC tube on the wall before it was plaster with concrete and for the surrounds I bought some wire covers with self adhesive at home depot and paint it. I haven't test the NS-333's as mains yet but I think they're very capable, I would recommend a good sub crossed at ~ 90/100hz as they don't go as low as the 555's.
those tables really ROCK
seriously though, great setup. I dig the wall of color, and the photography skills!
Discussion Starter · #19 ·
Discussion Starter · #20 ·
I'll update the first post later and fix the image problem but for now this is the latest addition to my system: dual JBL's ES250BK. They sound way better than expected....
1 - 20 of 20 Posts
