1 - 7 of 7 Posts
Hi
I used to have a 3 year old Sony Bravia and did not like picture quality.
I like the look of Samsungs but Sony made a GoogleTV.
Samsung UN46D6400UF
Sony NSX-46GT1
Can I get some input on which one I should get, and any potential issues if they are known. Or any other recommendation.
I play video games, is the Game Mode okay on the Samsung? That is the tv I am leaning to get
Thank you everybody
Originally Posted by iamdk1091 /forum/post/20882132
Hi
Samsung UN46D6400UF
Sony NSX-46GT1
Thank you everybody
Both companies make respectable options, do you have a budget? I assume you're wanting to stay in the 46 inch range?
Originally Posted by 6SpeedTA95 /forum/post/20883477
If you're patient and wait till the holidays it may be possible to pickup a 46in xbr 929 for close to your budget.
Just a thought.
I was planning on buying the Sony 46HX729 next week in time for football season and Resistance 3. However, you just mentioned in time for the holidays a possible discount into $1500 range on the 46HX929?
I wasn't paying attention to the past Holiday discounts on TVs but when do they usually start?
Probably more like 1749 or 1799...but 'm also just guessing. If you want a set now then pickup a 729 or the Samsung. I wouldn't completely rule out plasma either...
1 - 7 of 7 Posts
