People often ask me if a Linear Power Supply is a good idea. In short, yes, it can provide improvement. I have a few people who have switched to a Linear Power Supply and the feedback has been positive.
As I have discussed, HDMI jitter, and the electrical noise in the HDMI signal and back to the mains, can affect audio quality, and in some cases video quality.
I have discussed that lower-jitter can reduce the bit-error-rate of an HDMI signal. Lower HDMI clock jitter will also mean the de-jitter circuits in the audio processor start with a cleaner signal and so can send a lower-jitter signal to the DAC's. Lower jitter at the DAC leads to lower distortion in the audio. This can be heard, but how much is system dependent.
The linear power supply will act as a noise buffer between the Radiance Pro's high speed digital electronics and the mains. This noise reduction can improve the wall power going to the power amplifiers, and there is the possibility the lower noise floor may improve audio.
The Linear power supply also provides a cleaner, lower electrical-noise-floor power to the Radiance Pro itself. Noise floor can directly affect output jitter to some degree. Also a lower electrical-noise-floor in the Radiance Pro may mean a lower-noise-floor on the HDMI output injected in the the audio-processor and the projector/TV. A lower electrical-noise-floor can mean an improvement in the audio signal-to-noise ratio. For video a lower electrical-noise-floor for an analog display technology (DiLA and LCOS are analog at the display level) can reduce background noise in the image.
Note that I use "can" and "may" and "potentially" for these comments. I do this since any improvement is system dependent. You may not hear or see any improvement, but you might. I have heard some improvement form a linear supply for audio, but this is a subtle improvement. If you want the absolute best audio, then I believe you will be happy spending the money on an excellent "audio quality" linear power supply for the Radiance Pro.
I mentioned there is a chance that you might see a video improvement. However, if you do it would be subtle, and once again you may not see any improvement.
I wish I could be more adamant you will hear and see an improvement. Unfortunately any improvement is system and viewer/listener dependent. For those who want the best audio and video, I think a linear power supply for the Pro is a good investment. Just understand your mileage may vary.
I plan to purchase a Keces P8 12 VDC at 8 Amp single output supply (
KECES) as soon as they come back in stock, for my testing here. There are other brands of high end linear power supplies that could also suit this application.
