I have an upstairs room pre-wired for 5.1 that I am planning to make into an entertainment room for my family. It is currently an audiophile room. The speakers currently in the room are AMRIT-Towers (they sound great - at least to my ears) and are 12 years old. I was hoping to retain these speakers as my L/R fronts and augment them with a good center channel speaker. Some of the specs for the AMRITS are:
- Tweeter: 1" Metal Dome
- Mid-Range: 6-1/2" acouostic suspension
- Woofers: Dual 10", bass reflex, compounded
- Port tuned to 26 Hz
- Frequency Response: 23 Hz to 20 kHz
- Impedance: 7 Ohms (Minimum 4 Ohms)
- Crossover: 6dB per Octave
- Crossover Points: 4,500kHz and 240 Hz
My questions are:
1. Almost everything I've read on the forum seems to indicate that the left, center, and right speakers should all be from the same manufacturer - due to crossover points etc, and things I simply am not knowledgeable to understand. Is this true?
2. Some of the pretty good center channel speakers I was researching were the Aerial Acousics CC3B, the Von Schweikert LCR-15, and the Vandersteen VCC-5 (among others). Some of their statements seemed to lead me to believe that these speakers could be used positively with other companies L/R speakers. Is this true?
3. If trying to find a center channel speaker that is compatible with the AMRIT-Tower speakers, what do I need to look for within that speakers specifications?
4. If I'm simply barking up a hopeless tree, what L/C/R speakers would you recomment under $7,000.
To any who respond, I thank you very much for your time and input. I found this forum a couple of weeks ago and I've been simply overwhelmed by the depth of knowledge of the forum members and how little I know about anything.
My questions are:
