New product review - F-Conn radial crimp rca's
426 Views 0 Replies 1 Participant Last post by  minnesotalvs
[disclaimer]First let me say i tried posting this in the reviews section but i was not allowed to post in that section.[/disclaimer]
I was replenishing my supply of F-rca adaptors when i came across a new connector from F-Conn industries which eliminates the need for the adaptors. It's an rca that crimps onto rg-59 using a cable pro rtc-360 radial compression tool.
I must say, these connectors are a godsend.....eliminating the need for adaptors to run 1080i component video.
Anyone who is familiar with the rtc-360 radial crimp tool knows it's the best quality crimp you can get with an F connector, and now you can get that same quality in an rca connector.
Simply awesome, and they are a fraction of the price of "snap-n-seal" connctors and take up less space.
My uses for the lcct compression tool are now limited to right angle and quickport type connections
I highly recomend using these new rca fittings over the expensive snap-n-seal units
Heres a couple pics..........
http://www.lvsolutions.net/images/fconnrca1.jpg
http://www.lvsolutions.net/images/fconnrca2.jpg
I used up all the samples they sent me playing around, tomorrow i'll be ordering a couple hundred of these.
EDIT, one last thing, these connectors hold onto the mating rca lug tightly, no need to bend the 4 tabs to get a tight connection like a lot of f-rca adaptors
See less See more
Status
Not open for further replies.
1 - 1 of 1 Posts
1 - 1 of 1 Posts
Status
