Status
Not open for further replies.
1 - 7 of 7 Posts
I recently bought a 52" JVC HD-ILA TV and also had Dish Network's HD package hooked up. I mistakenly assumed that since they carried local channels as part of their package, that said channels would be in HD. I was wrong and would like to hook up an antenna to pull them in before the football season starts.
I am looking at a Channel Master 4228. I am about 4-5 miles from the local transmitters and they are all within about 4 degrees of each other. I do have a couple of questions though.
Is this antenna more powerful than I need? If so will that cause reception problems?
What kind of cable should I run from the antenna to the TV? Should I go top end? What kind of connections do I use?
Lastly what internet sites do you feel have the best prices? I looked on Solid Signal and would be paying $87 for a 4228 and a mast with shipping.
A 4221 will probably better suit your needs and be less expensive.
use RG6 coax for the cable run.
That close, have you tried a silver sensor or even a pair of "rabbit" ears? -- why not try that first being that you are so close to the towers. I am not saying that these will work but it can't hurt
Discussion Starter · #4 ·
I haven't tried that for this occasion. But two years ago before we got locals though the Dish, my reception off of an indoor antenna was not very good.
You don't want the 4228 at that range, it's possible to get too high a signal and overpower the input on the ATSC tuner. Give something like the SilverSensor indoor a shot if all your local digital stations are UHF.
1 - 7 of 7 Posts
Status
