New TV, Stand and Receiver. Need speaker help.
1036 Views 1 Reply 2 Participants Last post by  jakewash
I just bought a 65" Sharp, Sony 2400ES Receiver and this stand.
The image is not of my house, tv, or gear, but is the same stand. I have glass installed in all three windows, but am considering replacing the center window, (which is wood in that image) with a speaker grill for a center speaker.
I currently have 4 JBL HLS820's for the four corners, a 12" powered sub and a JBL HLS center.
My problem is that with the TV on the stand, I have no place other than that center slot for a vertical speaker. My HLS Center is too tall to fit by about an inch. I have been thinking of wiring the speakers on the TV to receive the center channel, but am concerned about the sound quality not being a match to the JBL's. I don't know the impedance of the speakers on the TV, but I can wire and adjust that as needed. I saw the thread in this forum about using the center speakers and I know that this is not encouraged by many people here. BTW, my tv speakers are in a removable bar and connected by a pair of wires to the TV. Easy mod.
Aren't the sound dispersion patterns of most center speakers designed for horizontal placement?
My options.
Use a ghost center. - not my first choice by far.
Find a bookshelf speaker to mount in the center slot on my cabinet.
Wire my TV speakers to the center channel output.
Mount the TV on the wall and put a real center speaker under it. ( don't want it on the wall, btw. )
Any suggestions?
Thanks in advance.
Paul
btw, the TV and Amp coming tomorrow. Yipee..
See less See more
1 - 2 of 2 Posts
You've got nothing to loose, try them all and go with what ever sounds the best. Although the TV speakers won't have nearly the range your present ones have so I would try to find a way to make your center work, either by mounting above or below the TV on a bracket of some sort, homemade possibly, or something of that nature.
1 - 2 of 2 Posts
