1381 - 1400 of 2406 Posts
Where did you find this?
What's interesting is that it mentions XMOS hardware decoding not Realtek, so wonder if they have moved away from current chipset for this....
Found here:
https://vk.com/clubzidoo
I presume XMOS decoding refers to the audio section - I think it safe to assume it's still based on the Realtek 1296 SOC with additional outboard audio handling.
Found here:
Yeah, found a post about it on the Zidoo forum. The XMOS is to enable use of USB interface out of Realtek RTD 1296 to the DAC to bypass some of the limitations of using I2S for high bitrate PCM/DSD.
End of the day it will come down the overall design and software implementation how good it really is. Would be interesting for someone like Amirm from Audio Science Review to measure it on his test equipment to see how good the hardware design is.
My opinion is if you're seriously into audio, you won't be buying a "media player" for it.
I use Linn DS for music and wouldn't dream of using a media player. Horses for courses again...
But that's just me :)
  • Like
Reactions: Apgood and dr4go
I sent an email yesterday about:
1. Separate TV & Movie categories
2. User definable Categories
3. Adding movie properties (badges) at scrape time
4. Show Audio & Video codecs in movie properties
I got this reply:
"Thanks for your suggestion, all of them will be feedback to engineers and hope it could be acheived.
But some of advice, like point 3, we are afraid it might not be acheived, as it could only know exact properties after it is played.
If there is update for HT2, we will inform you."
Shame about point 3, but that would seem to indicate that HT2, being a separate application, does not hook mediaInfo, but the player does.
On point 3 I noticed that Infuse on the Apple 4K TV has no issues in reporting full video and audio info for MKV, BDMV and ISO - for HD and UHD titles - without needing playback first. So its obviously possible. However it does report Atmos as TrueHD 7.1.
It just requires a bit more code - something like mediaInfo to open each media file as it scans (as yaDis does with the mediaInfo dll).
The Zidoo player itself calls mediaInfo which is why it can then report back into HT2 and provide the info screens but it obviously isn't called by HT2, but I'm not sure why it couldn't be.
I'm having constant issue with USB disconnections on Z9S; they are random but happen at least once while watching an hour program. I've tried both USB 3.0 ports. The program freezes, when i exit sometimes the posters have just disappeared or other times i get a message to say the HT2 has crashed. I reboot the box and it all comes back. It is getting very annoying now, the drive is a WD 3TB passport.
Would a powered USB hub help?
Has anyone else experienced this issue?
Do you use the DAC in the Linn DS? I'm using the DAC of my Trinnov. Almost all of my multi-channel Audio is in iso (BD, BD-Audio,SCAD,DVD-Audio).
I'm transferring the bitstream from the Ziddo and for the ones the Zidoo has problems with an OPPO. On the Quad recordings I'm using the OPPO multi-channel PCM (Auro-3D Auromatic will not upmix a Quad bitstream and I have not figured out how to force the Zidoo into multi-channel PCM). The extra shielding on the Zidoo clock chips seems to be solid. I'm not sure what the advantage is of a dedicated player if you are not using the DAC. Am I missing something?
Yes, I do use the Linn DAC as I assume it's of better quality than the amp, but either way it sounds stunning.
I also use Squeezebox for multi-room around the house and have a Transporter, which is good, but sounds very thin compared to the Linn..
I have a single 10TB USB drive connected to Z9S. Over the months I've been ripping my disc collection to it. Initially I was not concerned about a backup because the discs themselves are a backup, in a sense. But now that I'm pretty deep into this, I think about the time and labor to re-rip everything if the drive fails.
So I'm thinking about adding a second drive as a backup. I see there is some sort of backup function in the Zidoo, but it's unclear to me what it does. I think it's more of a system backup, but I'm not sure.
Can I buy a second 10TB drive and use that function to have some sort of automatic, periodic backup of the existing media drive? If not, can anyone recommend an Android application that would be good contender for doing that?
Why not just get at the very least a basic Raid 1 NAS?... so a backup is automatically performed everytime you write to it?
Yes that's a reasonable route, but not for me. Here are my reasons:
1. RAID is not a backup. That is a common misconception and there are important differences. RAID is redundancy that protects against HDD failure only.
For example if I do a bunch of management and screw things up, or accidentally erase the drive or something, with a backup available there is something to restore from. With a RAID, the screwups are instantly mirrored in real-time on the redundant drive. Admittedly my main goal for backing up IS to protect against HDD failure, which RAID does, but I'd rather have a backup than RAID.
I've done RAID twice before and the complexity adds its own problems. For example the RAID enclosure itself becomes a single point of failure. If it fails, you lose access to both drives. In some cases RAID can also have weird formatting that prevents it from being usable if you hook up a drive directly to the host.
With separate USB drives, if one HDD enclosure fails, the other is still working. And both drives have formatting native to the host device.
2. Existing capability / Simplicity. The Zidoo already features NAS. Why would I buy another one? I already have one 10TB USB drive. I plugged in the drive and enabled SAMBA. BAM...network attached storage. Simple and clean.
Buying another NAS means spending more money duplicating something I already have. It means another device to power, learn, configure, troubleshoot, and maintain with updates. I see a lot of negatives and very little benefit.
3. Cost. I'm looking at simply adding a second USB drive to the Zidoo. That's much cheaper than a NAS with an equivalent size internal drive.
So having been down this road before, this time I'd just like to have a second drive and some app to do a periodic backup from one to the other.
I agree on the raid NAS. I have had issue before and lost contents, even with mirrored raid (couln't get anything offf the drives when the unit died).
I haven't really come up with a good system myself, and currently work on the basis of manual redundancy, so manually copy the media to multiple external drives. It would be nice to have something to regularly check it or something. This is another reason I prefer pressed optical media for my entertainment... My other redundancy is just rebuilding the remuxes if I ever need to. My music and pictures, I do have an online backup. For video, it just isn't feasible.
Some very good points raised.
Exactly the reasons I use (or did until recently) Western Digital My Cloud single drive NAS drives - one with the movies and one as a backup - currently I have 8x4TB drives for 2K movies (inc backups) and 4x8TB for 4K (inc backups).
When I copy a movie over to one, I simply copy it the other at the same time. One drive goes down, I switch to the backup and immediately replace the faulty one. That's happened twice to me now.
Stupidly, Western Digital have recently replaced their My Cloud drives with My Cloud Home drives which means you lose all NAS functionality - no ability to create and manage shares - it's all managed in the cloud now with their crazy proprietary system, so I'm currently looking for a new solution.
RAID can be a solution as long as you're careful about it - something like the Western Digital My Cloud EX2 configured as RAID 1 is fine - if a drive goes down you can slap a new one in and it rebuilds, and if the enclosure goes down it can be replaced. If all else fails each disc can be mounted and read as Linux partitions (I think they're EXT4).
But simplest and safest is two separate NAS drives - and they don't have to be collocated either.
GUI Refresh Rate for ZDMC Question
I can set 23 (23.976) for the Z9S display refresh rate in quick setting. However, I can not match it in the ZDMC interface that only lists 24.000. Is there a way to add the 23 (23.976) choice to the ZDMC so it shows up under Display / System / Refresh Rate? I don't want ZDMC to change the refresh rate when started. I would like to match the setting for the Z9S so it has no reason to change. I would also like to have it 23 so it will again not need to be changed for most bluray/4K content on playback.
I want to minimize refresh rate changes as my projector is slow to adapt. Is there a way to do this?
Have you tried setting "Ignore EDID" to in developer options?
This used to be required to bring up 4K23 as an option in Zidoo quick settings, but it will still be needed for ZDMC - there is certainly a 4K23 option in ZDMC on the X9S (I don't have it installed on the Z9S) if it is set.
I might need to look into that. So the cloud stuff is more management?
The new My Cloud Home drives are a piece of s**t.
I bought two thinking they were just an upgrade to the My Clouds but they've completely changed the way they work - supposedly for home users. They went straight back to Amazon.
They're not true NAS drives anymore - You can't create local shares for example, which is just madness - all you can do is log into the MyCloud website and create a URL link.
There's no dashboard, no controls.
It's basically like dropbox without all the features..
I'm testing an EX2 at the moment which seems ok, but has issues with sleep mode.
… there is certainly a 4K23 option in ZDMC on the X9S (I don't have it installed on the Z9S) if it is set.
So I feel sheepish. Turns out I had installed the "release" apk from the main zidoo advert/download page and that is version 17.6. A newer Version 17.6.1 from GitHub as found via their support forum has a "Fix 23.976 framerate output". That is the only thing in its one line change log but I did notice the apk for the newer version is much smaller. After installing 17.6.1 the option 23.98 shows in the system settings now. Also want to give a shout out to the add-on "Backup" that allowed me to make a backup of my 17.6 zdmc and restore it after I updated to 17.6.1 (since it required a delete of the original 17.6). I mention just in case someone else figures out they have the older version. See post:
Here Worked great.
They really should really have the newer version on their release download page from their main site. :( Oh well. Search and ye shall find I guess.
