1861 - 1880 of 2425 Posts
Hello. Yes I have 3 of these attached via powered hub to one of the 3.0 usb outlets on the z9s. No issues other than the drives never 'sleep' maybe because of the powered hub. I do have the 'sleep setting' for external HDD's on the z9s turned on. Drives show up on the network and windows explorer on my PC.
I think max drive size is 14tb but I could be wrong.
Hope this helps!
Thanks for the info...being able to use a powered hub is great news.
I wound up using a WD 10Tb drive and it works great. It's connected to a usb2.0 slot because of the continuing problems with the usb3.0 still having sporadic freeze issues. I have no issues with the 2 slots.
I also just updated to 2.3.7 yesterday and it went well. I was having a glitch with the user interface...after watching an episode of a show it would go to the folder then the screen would go black for 5 seconds then go to the folder again. The update fixed that glitch but perhaps started another...when using the volume control for the avr the volume display would appear but since the update it doesn't...not a big deal at all but it is a glitch.
I'll power off/on the Z9 and do a cache clean up, etc. to see what happens.
I haven't checked out all the areas the update "fixed" but will try to today.
Thanks for the input.
I played the 59.94 UHD rip (Gemini) on the "Z10", I get audio drops and lip sync problems. :mad::confused:
If you can cut a 5 minute clip using mkvtoolnix and share, I can try it on my Z9s and other players. If you want...
I get audio drop out now and then, I stop the show and go back then start again and click on "continue" and it resumes with no problems.
This seems to occur when I'm fast forwarding through the intro and go a bit to far before stopping and play.
It doesn't happen often but when it does that is usually the reason and the remedy...at least when it happened to me.
Keep in mind that with this title's higher frame rate, could it also be exposing a network throughput/bottleneck issue with your network or setup? If using a NAS, you may wont to reboot it and try again.
My Zidoo Z9S used to be rock solid and could run for months. But lately it's been locking up frequently, mostly when copying files to the SMB share. I have to cycle power to get it working again.
I'm thinking about trying to revert the firmware, since that is about the timing when the problem first started. But I thought I would first ask if anyone else is having the problem, or if there is a known solution or workaround.
Like most Android 4k mediaplayers,you can install Apptoid(i believe...was months since i did it ) and then side load the version of Youtube which allows full 4k Youtube
Works well on my X9S,and ive seen others with the new Z9S say it works for them too
Can anyone advise how to do this, or where to download from? I've tried searching the thread but search here doesn't work too well.
Hi Guys, I am currently using a WDTV Live and statring to encounter issues so I am looking forward to upgrade. Would the Z9S would be a good solution for the near future?
I mostly stream movies from my NAS in 1080p and HD Audio (Atmos, etc.). I plan on getting a 4k projector in the next year so I will stream in 4k x265 in the future.
I liked the frame rate matching with the WDTV.
Will the Z9S be a good player for me?
The short answer is yes. All these players have some issues, but Zidoo is probably the best a frequent release updates to address them.
The 1-on-1 REMUX for me is not even playing on the Z9S. On the NVidia Shield 2019 with Kodi it plays with an occasional audio hiccup. On the AppleTV with infuse it plays like a charm but of course no Atmos.
That’s my experience.
Model: ZIDOO_Z9S
Version number: v2.3.10
Changelog
(From here, translation via Google Translate.)
(original text below) / (оригинал ниже)
System
1. Optimize the problem of the USB 3.0 port even if the device is lost
2. Fix DTS full-track music can not play problems
3. Repair HIFI music sporadic automatically at a problem can not be played
4. Optimize online play
The "information" button to display the current HDMI output
6. optimized music pause play DTS sound unusual problem
7. Repair HDMI output is set to source output, Bluetooth devices abnormal sound problems
8. Repair very few sources, Dolby Atmos audio playback of the Caton problem
9. DLNA voted screen function optimization
File manager
1. Fix the problem that the same share name is displayed in NFS (for Usbshare multiple external hard disk cabinets, only one can be found)
2. Cancel the top navigation classification, increase circulation list
3. Increase CD-ROM into tips
4. Optimize sorting function (save separately by path)
5. Added the function of pressing "Popup" to return to the top of the list
6. Fixed the problem that the played video does not prompt the watched icon
7. Modify the problem that the volume label does not display more than 20 characters
Poster wall
1. Optimize the display of the details interface and the movie video
2. Optimize segmented video scanning
3. Optimize scanning to solve the problem that stopping scanning during scanning may cause unmatched videos to not match properly when continuing scanning
4. Solve the problem that the child lock set is not displayed synchronously after the movie rating is initially set
5. Increase the HDR corner mark (scanned videos will not be displayed)
6. Optimize file name recognition
7. Optimize application stability
8. Optimize bracket processing for title recognition
9. Added trailer filter filtering, the word 'trailer' in the file name will no longer be scanned
10. Optimize the NFS mount method
11. Fix the problem that the background service causes the setup wizard language to be incorrect
12. Fixed the problem of disordered video in the folder video list interface
13. Fixed the problem that poster information cannot be obtained based on the file path
14. Fixed the problem that the total number of videos on the device does not change after moving the video out of the poster wall
15. Clear device and delete device will remove related video information from database
16. Fixed the issue that the poster does not refresh after modifying the rating of the child lock
17. Child lock setting interface adds function description and child lock reset function
18. Optimize the collection function
19. Fixed the issue that playback records cannot be saved when playing NFS source
20. NFO added sorttitle field support, only use this field for sorting in movie collection interface
music player
1. Optimize folder browsing function
2. Add CD playback function (requires external optical drive)
3. Optimize the sorting function
4. Optimize the calculation method of scanning progress
5. Optimize track identification for SACD and CUE albums
6. Improved the interface of obtaining track list, and solved the problem that the mobile phone cannot control the CUE / DSF track list of the temporary list
7. Modify the time display format of CUE to keep the same with SACD
8. Optimize focus control logic to solve the problem of focus flicker
9. Modify the recording method of the playlist to solve the problem that the last song in the random play mode will replay randomly
10. Added screen saver function in play details interface
11. Fixed an issue where the list interface displayed an error after the grid layout removed the list
12. Fixed the problem of getting albums when playing music from file manager
13. Fixed the problem that the lyrics could not be closed without playing the details interface
14. Fixed the problem that sometimes the detailed interface picture cannot be obtained
15. Added automatic full-screen playback switch
16. Added music file information display to the list
17. Solve the problem that search interface focus may be lost
18. Fix the problem that the song is cut abnormally in the playback interface
19. Modify singer details interface
-Add album sub-categories, you can directly enter album details from the list
-Add picture subclasses, you can set the default, delete and add operations for pictures
-Add details sub-category, you can browse all the information of the singer
20. Add "View Artist" and "View Album" functions
21. Add song names that do not match the file name "track + number"
22. Fixed the problem of flashing back when pressing the "Home" key in the folder song interface
23. Fix the problem that Bluetooth remote control connection stops playing
24. Add multi-folder scanning. The abnormality will be displayed after the scanning is completed, and the normal display will be restored after all scanning
25. Fix the problem that the time of the song displayed on the front panel is incorrect
26. Fix the problem that the sample rate of the playback details interface is incorrect.
27. Fix the problem that some DTS-CDs cannot be played
Local player
1. The problem that the optimized bit rate is displayed incorrectly
2. Fix the problem that the movie name is displayed incorrectly
3. Add ZOOM function
4. Increase the video ratio
5. Fixed the issue that Polish subtitles are displayed in Portuguese
6. Optimized subtitle download function
7. Optimize the front panel USB icon display
8. Optimize the problem that DVD cannot select chapters
9. Optimize ASS subtitle display
10. Fixed the problem that the srt subtitle space is not displayed completely
11. Fixed the problem that the file name of the DVD folder was displayed abnormally during playback
12. Optimize the setting of video scale interface display
13. Add sequence play function
Blu-ray navigation
1. Added the function of subtitle track list displayed by shortcut keys
2. Optimize subtitle download function
3. Fixed the problem of incomplete display of srt subtitle space
Quick settings
1. Add ignore EDID function
2. Increase video playback order
Scheduled shutdown
1. Modify the problem that the traditional display is abnormal
Picture Manager
1. When optimizing the slideshow, the picture is blurred
the weather
1. Optimize the problem that the weather is not available in some cities
Mobile APP (need to update mobile app v.1.5.5)
1. Add audio offset setting in the setting interface
2. Folder browsing function has been added to the music device interface
3. Application interface adds sorting function
4. Fixed the problem that the same device is repeatedly added to the music device interface
5. Fixed the issue that the CUE / DSF track list cannot be obtained from the temporary list songs
6. Optimize the problem that the application interface icon is not displayed
7. Optimize poster wall interface display
8. Solve the problem that the file management is affected by the search bar, and it will return to the upper directory when rescanning SMB or NFS
9. File manager adds list refresh function
10. File Manager adds CD-ROM drive list
Gofile Mirror: https://gofile.io/?c=0t0Jl4
How to upgrade: http://*******/2RgPFA6
MD5 Hash: 8A5C466B604B13BD874D26E10B672AB8
Posted on @ZidooNews
Model: ZIDOO_Z9S
Thanks leonkoum :)
I'm glad to see certain bugs fixed.
Is there a way to improve the downscaled 4K-->1080p picture? On 4K tv the picture quality from UHDBD is good.
But connected to a 1080p tv, UHDBD doesn't look good. Quality of 1080p BD source of the same movie is great though.
Seamless branching still not fixed though (Again) ?
Nice to see regular updates but really need to nail seamless branching and improve blu ray menu support.
