Hi everyone. I've been lurking for awhile on the boards and I think I've learned a lot but now I'm ready to buy my projector and screen and need your advice.
I will be watching HD sports, DVD's and HDTV all in fairly equal proportion. The room can be pretty well light controlled but it's cave-like at all (fairly light colored walls.) Also, I don't want total darkness when watching my Steelers (next year sadly.)
My budget is $4,000 - $6,000 or so for the projector and hopefully less than $4,000 for a motorized screen.
Some distances:
There will be one line of seats (a couch actually) where the viewers will be 10'2" from the screen.
They'll be at normal height (say eyes at 36").
The projector will be 10'6" from screen in a shelf-like cutout in a soffit.
The height of the shelf is 9'3". T
So from everything I've read, it looks like I want a screen that is 80" to 85" diagonal and I need A LOT of lens shift.
In fact, from my calculations, even if the bottom of my screen is as high as 36", the only projector in my budget neighborhood that has sufficient lens shift to avoid digital keystone correction is the Panasonic 1000.
So here are my quesitons:
1. Will the Panasonic work well with this setup? Are there any other projectors in this budget that are worth considering given my lens shift requirment?
2. What screens should I consider? Not knowing a whole lot I am considering the Stewart FH. IF the FH is a good choice which version should I get (3G, SST other?)
3. How high should I put the bottom of my screen?
4. Other things I should consider?
Thanks in advance for your help. This forum is an amazing source of information and help.
Jonas
Some distances:
Jonas
