Status
Not open for further replies.
1 - 1 of 1 Posts
Can someone help my confusion about 921 DVR capability and hookups?
I'm finalizing equipment for a new HT, and seem to be bumping up against a wall with limitted knowledge on my part!
I was planning on viewing JVD D-VHS 40,000 using firewire output to Samsung SIR TR165(which would act as a firewire to dvi switcher) , and using the TR165 DVI output to the projector (Marantz S3 with dvi/hdcp input)
Mu questions are:
1) To insert a hi def DVR/satellite dish receiver into the path, such as the Dish DVR 921, with firewire output connecting to JVC 40,000 for recording (and then presumably thru above pathway to achieve a firewire-to-dvi switch).
Does this work?
2) The 921 also has "dish DVI", presumably a dvi/hdcp output. Is this correct?
Would this be used to connect directly to the projector dvi input also, bypassing the 921- to dvhs -to firewire/dvi "switch" pathway ?
Thanks in advance for the help!
1 - 1 of 1 Posts
Status
