I've got a 5 month old KV36HS510. I recently got a Zenith OTA HDTV STB from CC just to see what HD looks like before investing the bucks in a HD-TiVo. When I watch CBS (from NYC), and as an example David Letterman, it comes in as nice sharp but very SMALL (27" diag) square picture in the middle of my nice BIG 36" diag screen (I assume this is a 480i broadcast). VERY annoying for an expensive "HDTV" set. If that's the way it's going to be I'm not going to be a happy HDTV'er. I was looking for some sort of "zoom" feature in the menus but it obviously isn't there. I can understand the 16:9 1080i being letterboxed but why should 4:3 480 be "shrunk" to a small square in the center of the screen rather then expanded to full screen ?
The Zenith STB I have does NOT have DVI OUT but the TV is DVI capable so I'm using component input. I'm wondering (hoping) if using DVI would fix that problem.
I know I can also use composite, but my intent is to get a HD-TiVo and recording this "small" image just seems a waste. I also think FOX has this same issue.
Please, no "you shudda got a widescreen set" ..... I couldn't for MANY ($$$$) reasons ...
Is this "small square" normal for a 4:3 tube based HDTV set ?
