Status
Not open for further replies.
1 - 6 of 6 Posts
Can someone point me to the FAQ or thread that best explains what is required for Direct TV HDTV reception.
I understand that both analog OTA of local HDTV content exists as well as DirecTV HD content. It is also my understanding that Direct TV is the only way to receive both SD and HD off a single dish.
I have already purchased an 18" round dish, but it seems I need the eliptical dish instead. Is this the case?
What do each of the 3(?) DirecTV satellites provide as far as content is concerned?
TIA,
Kelly
It's actually digital OTA.
Using a single eliptical dish. Yes.
There is another thread with the topic of using 2 18" dishes instead on an eliptical dish.
101=Main programming
110=Some locals in North Carolina
119=Spanish channels, HDTV, NASA and some locals (I think)
Discussion Starter · #3 ·
Thanks for the help.
Kelly
Kelly,
You could go with DISH network and use your 18 inch round dish for HDTV 148 bird and get a TWIN LNB Eliptical for 110 and 119. They point about 90 degrees apart and can be mounted on the same pole. A simple SW21 to combine with a DISH 6000 receiver and OTA module. A good VHF UHF antenna and you are in business. Channels 3,6,10,12,29 broadcast digital signals as well as analog.
Impala Bob
VS-50803 and DISH 6000 w/OTA module http://www.avsforum.com/ubb/biggrin.gif
Discussion Starter · #6 ·
Where the heck is Schwenksville? I'm in Center City.
I'll look into Dish guys. Being downtown, location of the satellites is important with big buildings all around me.
Kelly
1 - 6 of 6 Posts
Status
