Status
Not open for further replies.
1 - 2 of 2 Posts
Discussion Starter #1
I've received soem REALLY GOOD advice thru these forums. THANKS! Anyway, on to business. I want to get a decent, low cost home theater setup. I was leaning toward the Kenwood HTB-504 coupled to a Panny RP-91, but many have said yes to the Panny and no to the HTB of any brand. I'll have about $350 budgeted (I really meant it when I said low cost). Where the system would go is in the lower level family room in a bilevel. There's a fireplace at a 45 degree angle in the corner, birck floor to ceiling. That's one reason for the low cost angle. (Have two kids, one in college is the other. SHEESH!)
So, any one out have any good suggestions?
BTW- My brother got some Martin Logan speakers for his room. He likes.
LilBro,
I used to have the Kenwood HTB-503 and was very happy with the setup for the cost. I have since upgraded to a higher level of equipment, but for the money I was very happy with the purchase of the HTB-503. If that is the budget you are looking for, I would recommend the Kenwood HTB 503, or whatever the new model is. Good Luck
1 - 2 of 2 Posts
Status
