1 - 20 of 82 Posts
I'm setting up a new 5.1 surround system in a 16x18 room. I think I've decided on the Denon AVR-E300 receiver, and I'm wondering if the Energy take classics would be a good match for said room size and receiver? My budget for both receiver and speakers is no more than $700. Thanks for your wisdom in advance. Any suggestions would be appreciated as well. My former experience with home theater has been Onkyo HTIB systems. Seemed fairly decent to me, so I'm just wanting to possibly step up a little in quality if possible with the budget mentioned. Thanks again guys!
Those are small satellite speakers, and will not work well in your medium size room. Here is what I would recommend instead:
Buy a Denon AVR-E300 from www.accessories4less.com It is manufacturer refurbished and has a warranty: http://www.accessories4less.com/make-a-store/item/DENAVRE300/DENON-AVR-E300-5.1-3D-Networking-Receiver-AirPlay/1.html
With the rest, I would recommend the Pioneer Andrew Jones speakers, you can listen to them at Best Buy, but they are regarded as one of the best budget speakers out there. I would start with a 2.1 set, and add a center and surrounds later on. You can get a pair of the towers for $250, and then add a NXG BAS 500 sub to give you a great starting point.
Sub: http://www.amazon.com/NXG-Technology-NX-BAS-500-500-watt-Subwoofer/dp/B008FSTU4G/ref=sr_1_1?ie=UTF8&qid=1393600292&sr=8-1&keywords=nxg+bas-500
Speakers: http://www.amazon.com/Pioneer-SP-FS52-LR-Designed-standing-Loudspeaker/dp/B008NCD2S4/ref=sr_1_4?ie=UTF8&qid=1393600207&sr=8-4&keywords=Pioneer+speakers
This will be a night and day upgrade over those Energy speakers, and you will end up with a much better system.
Discussion Starter · #5 ·
How difficult is it to set the Denon up with the two pioneer fronts and just the sub for now? Without having the center and surrounds. Will the receiver just automatically adjust to not having the other speakers connected? Sorry for such a newbie question. Thanks again.
Originally Posted by Gpc777  /t/1520234/newbie-help-please-energy-take-classics-in-a-16x18-room#post_24421609
Yes it will. It comes with Audyssey MultEQ room calibration software and a mic. You plug in the mic and follow the on-screen instructions. It will detect what speakers you have, and determine the proper settings for them.
They are great speakers for the money, and that center speaker does fine. You would have to use it regardless, or another tower/bookshelf because you need to have the front three speakers timbre matched for proper imaging.
Originally Posted by Gpc777  /t/1520234/newbie-help-please-energy-take-classics-in-a-16x18-room#post_24421778
Excellent. Is that matching Andrew Jones Pioneer center speaker a good one? Thanks.
The Pioneer SP-C22 is the matching center to the Pioneer SP-FS52-LR Andrew Jones Designed Floor standing Loudspeaker
Originally Posted by Gpc777  /t/1520234/newbie-help-please-energy-take-classics-in-a-16x18-room#post_24422131
One more quick question. Is it best to place the sub in the front of my room on one of the sides, facing me, or in the back of the room? Thanks.
Subwoofer position varies per room to room. To figure out the best position in your room its best to do the " subwoofer crawl "
What subwoofer are you looking to get with your speaker system. I would suggest against the Pioneer 8" subwoofer and go for something like the Dayton Sub-1200 .
Discussion Starter · #14 ·
Not sure as far as the sub. Transmaniacon had suggested the NXG Technology NX-BAS-500 12" 500-watt Powered Subwoofer for $250, but if the Dayton sub-1200 is close to the same quality for $110, that would be an awesome money savings. Also, how are the pioneer SP-BS22-LR speakers compared to the 52-LR speakers mentioned above? If paired with a nice sub, wouldn't they still blow away the old Onkyo speakers I'm used to? Sorry, just trying to save some money here. Maybe use the 22-LR's with a sub and the matching SP-C22 center channel at first, then buy the 52-LR's at some point, and move the 22-LR's to the back for my surround speakers? What do you guys think? Thanks again!
Originally Posted by Gpc777  /t/1520234/newbie-help-please-energy-take-classics-in-a-16x18-room#post_24422307
The NXG is a noticeably better sub, it will dig deeper, play louder, and be more articulate. When it comes to internet direct brands, sub woofers scale pretty well with price so the more you spend the more you get. I would definitely not skimp on the sub, it, along with your center, shoulder the load in a HT. You can definitely go with the BS22's as fronts, with a good sub, the difference between towers and bookshelves is small, and with the difference you could add the center and start with 3.1. I have heard both and the towers offer better dynamics to me, but either is fine and a big upgrade over the Take Classics. As you laid out, you can eventually upgrade the fronts, or simply just buy another pair of BS22s for surrounds.
Discussion Starter · #18 ·
Thanks again. What about HDMI cables? Do I need the newest 1.4 or whatever standard it is to run from my display to the Denon receiver? Just want a good 1080p picture, nothing more than that. Thanks.
Originally Posted by Gpc777  /t/1520234/newbie-help-please-energy-take-classics-in-a-16x18-room#post_24422583
Don't spend a lot on HDMI cables. For instance, these Amazon Basics HDMI cables should work well
Originally Posted by lovinthehd  /t/1520234/newbie-help-please-energy-take-classics-in-a-16x18-room#post_24422510
Sub blending isn't about brands/models, it's about bass management and placement in your room.
+1
That NXG sub will work well and would be worth the investment.
1 - 20 of 82 Posts
