Status
Not open for further replies.
1 - 3 of 3 Posts
I have found the 4248 to be the best performing antenna in the CM line up for multipath. There are better antenna's, but they are more expensive and harder to get.
Glenn
I have a small Mt. with a lot of different antennas on it about 4 miles in the distance. My line of sight to Mt. Wilson which is where my DTV comes from is right through this small Mt.
I had a CM UHF/VHF/FM antenna up and was suffering a lot of muiltipath problems but I was getting signal lock in the high 50's on the worst channel and in the 80's on the others. I then put up a Ratshack U120R UHF only antenna and still seem to suffer mulitipath problems.
My question are:
Should I try the CM 4228 over the Ratshack?
Would an amp help?
What type of amp - indoor or on the antenna?
I used the transformer from the CM UHF/VHF on the U120R, could this be a problem, do I need to change?
Or am I just out of luck because of this small Mt. in my way?
Thanks for any insight you can provide.
1 - 3 of 3 Posts
Status
