Hi all! I have been immensely enjoying this forum. Because of budget constraints, I am contemplating a worn/burnt set that i can 'fix up'. I found this explanation of marquee tube replacement/alignment and am wondering if this applies generically to all crt, or just that model? If it is not generic, does anyone recall a thread that describes the process for a NEC PG model?
from this thread
I saw several posts where people describe putting this electronics back on the tube 'as close as possible to the original tube.' Is that adequate or is this the necessary process?
Ideally I find a set that is toasty but watchable so I can learn about crt some before needing to embark on this. A brown tube is going to look so much better than my 31" rca tv that I think I'll muddle through until new tubes :~) Anyway, I've worked on crt monitors some in the past in a limited sense, and have a decent technical background, so I'm just wondering how insane I am to contemplate this?
Thanks for any help here!
from this thread
VDC would have you strip the various yokes (magnetics) off each tube before sending them in; correct realignment is a bit of work. The front yoke is sweep and must be set for level horizon, I start with green and match the other tubes to green; then set those with hot melt glue. The convergence yoke is next and must be set so that zone correction is proper vertical and horizontal; this yoke is then clamped to the tube neck and glued to the scan yoke in front of it. Next in line is the focus yoke; it also acts something like a centering magnet, the focus yoke is aligned together with the flare magnet rings (rearmost yoke) to give a concentric flared dot shape AND a centered raster with no static correction applied. These alignments are better done with the tube covers off; the tubes are lifted up and the covers go on last. Whew! And this is part of why a skilled retubing job takes most of two days. Those reluctant to undertake all of this, which involves reaching amid lethal voltages in a running projector chassis, can send Marquee tubes or the entire projector here for strip-down and reassembly. Also, sweep yokes come hot-glued to the original tubes and can be damaged if not removed carefully. |
