Newbie needs help picking a receiver. Thanks!
417 Views 6 Replies 5 Participants Last post by  Antonpd
I've decided on buying the new Samsung HSL5088W (DLP) set. I'll also be purchasing a center channel speaker for over the set as well as four in-ceiling speakers and a sub. I'm probably going to wait a bit on the DVD player until things shake out a little (my old one will do for now). My HD feed will come from DirecTV (receiver/dvr).
Note: The Samsung DLP set accepts 1080p over HDMI and comes with two HDMI inputs.
I've got no idea what I should be looking for in a receiver to run my system. Please recommend any and everything I should be looking for. Thanks!
Mike
Status
Not open for further replies.
1 - 7 of 7 Posts
That's a pretty basic setup. If you're using the inputs on the TV and no going through the receiver, just about any receiver would be fine.
Do you have a budget?
Will the speakers need a lot of power? Any "Ohm" requirements for the speakers?
I'm buying everything through Tweeter. The salesman told me that everything should run through my receiver and then run via the HDMI cable to the TV. I've read a lot about scaling, upconverting, deinterlacing, etc. etc. and now my heads about to pop and I've got no idea what features I should be looking for to best compliment my choice in TV's as well as speakers (in-ceiling direction Polk Audio's) and sub (not yet chosen).
I know this is all pretty vague, but.....I'm truly lost in regards to a receiver.
bump................anybody? Any advice would be greatly appreciated.
Don't pay too much attention to what the salesman says anyplace. I am not saying honest knowledable salespeople don't exist, I am sure I have met one once (now retired), but the odds are heavily stacked against them steering you in any direction other than their sales bonus.
The weakest element in reasonably priced Receivers is HDMI switching. The high def DVD players haven't fully settled how the copy protection authorization works, and my guess is the dust won't fully settle for many months, so most of what I have seen in receivers is VERY simple like 2 input passive switching. Routing everything through the receiver immediately steps you up to only the lastest premium models.
What most people do for now is route all the Audio and standard def Video through the receiver, and hook up the high definition source directly to the display via HDMI or DVI depending on what it supports. Do it this way an really any decent quality unit made in the 5 or so years should be fine for now.
If you have to put speakers in the ceiling, I guess thats just something you have to live with. Quality has certainly improved over the years, but its still costly and inferior to free standing speakers, even really small ones (as long as they don't start with a B and have 4 letters). I have to wonder what the center channel with all the dialog will sound like coming from the ceiling. Make sure you get a contractor that knows sound.
I tried a search for Samsung DLP HSL5088W and didn't find any reference to it outside of this forum, so I had to guess a bit on inputs etc. All this is of course just my opinion, and I am just another normal person, but with no requirements of any kind its hard to make any suggestions. Brands I like are Onkyo, Sony, HK, and Yamaha for a start.
See less See more
Spend some time in the speaker forum and ask around. Traditional thinking is that in-wall and in-ceiling speakers completely stink for home theater. Check it out in the forum before you make your final decision.
I recommend you avoid any HDMI receiver until HDMI 1.3 is finalized and widely available. Get an interim reciever for the next couple years, between $250 - $500, and just directly input your video sources to your tv. Last thing you want is having an expensive HDMI receiver which doesn't process the new HD audio. I realize the player can decode the audio and just pass PCM but I'd like a choice. Or maybe you don't care about any of this uncertainty..... up to you :D
1 - 7 of 7 Posts
Status
