Status
Not open for further replies.
1 - 7 of 7 Posts
Banned
Hi i'm new to home theater but not to films.
i 'm currently constructing a home theater in the garage, about 12' by 8' .the equipment i have accuired so far is :
projector sony 1270qm (will be floor mounted)
screen 84" (16:9) dalite
quadscan pro
pioneer dv-09 (region 1)
sony dvp-s7000 (multi region ntsc)
denon avc-a1
denon avd 1000
mordant short speaker, front , centre, rears
rel 100 sub
cable - advice needed will be around 12 feet long hd-15 to 5 bnc
feel free to comment on current items or suggest upgrades
none of this is in position or been tested all together
i'm on a small budget about £ 500 left ($750) all the above equipment has been collected for a total of about £ 1500 ( $2000-$2200)
i will be watching about 95% ntsc dvd and 5% sat
thankyou for taking time to reply
Mark
Looks like your set. The only thing I would suggest is that you get a calibration disc such as Avia or Video Essentials, if you don't already have one. Enjoy!!
Now, you don't really want us to suggest upgrades do you? We could easily send you to bankruptcy court. :D
Banned
Discussion Starter · #3 ·
thanks for the kind words, i have the avia setup disc.
the upgrades i had in mind were small ones that all you experienced home theater uses may have noticed.
at least i'm going in the right direction
thanks
Mark
Even with monty tubes, I would run the Quadscan in line tripling mode rather than quadrupling. Try both, but I thik you'll be sharper in tripling mode.
For about $200, you could get an Extron 202 booster to bring the Quad signal output up a bit. It'll punch up the image a bit.
Curt
Mount the PJ on the ceiling. It'll be right against the back wall so you'll have to sit beside it. This'll give you only 2 good seats, if you put 4 seats in, the 2 front will be too close.
My 2 cents
Wes
1 - 7 of 7 Posts
Status
