I just purchased a Sony 1031Q CRT projector, it came set up with 72" CRT spacers behind the tubes, I wanted to set it up using the 100" CRT spacers, and readjust the lens rings for a 100" screen. I ordered the correct spacers from PSI,They sent me 4 wedge shaped spacers, I was going to change it today, but I was looking in the service manual , it also shows when setting up for a 100" screen, 3, 0.8 mm spacers that go at the bottom of all 3 CRTs with the 100" spacers on the 2 outside CRT's, PSI did not send those spacers with the set, and the 72' set up does not use them, my question is , If I go ahead and set it up without the 3 0.8 mm spacers, what affect will it have on the picture quality, will it affect calibration, focus ? , I was thinking since it was removing a small, equal amount from each CRT , and they would still be in correct alignment to each other, it shouldnt affect it to much, but I could be wrong
All help is much needed and greatly appreciated,
Thanks, ED :
Thanks, ED :
