Status
Not open for further replies.
1 - 3 of 3 Posts
When a computer's specs say:
video = On board
sound = on board
what does it mean?
Does it mean that I am stuck with the
video and sound cards on the mother board?
Or can I switch those for better components?
Thanks for help
For example:
If you see -
www.unitedmicro.com/comp_main.htm
you will see that several of them mention "on board".
What precisely is meant by that term?
It means the parts are soldered into the motherboard. Usually you can disable both within the BIOS at bootup if you want to use another AGP/PCI card. Better to just avoid any boards that include on-board stuff since you're paying for features you won't use.
On board sound is not necessarily bad. P4PE has on board SPDIF which is quite good.
On board video on the other hand is usually a real looser. The video system is sharing the system memory which means PCI bus activity for writes to the screen.
1 - 3 of 3 Posts
Status
