Status
Not open for further replies.
1 - 7 of 7 Posts
Hello all, 1st time posting here
I have a birthday coming up on 8/20, and my wife wants to get me a DVD recorder, but I have a few questions
I currently have 2 Directivo units that I want to archive off of and onto DVDs. I would like to be able to edit the commercials and beginnings and ends off of them also.
I also have a small DVD collection that I would like to make copies of for family and friends.
I was looking at some DVD recorders with harddrives on Ebay, mainly the Panasonic DMR-E80H, but they have gone over $250
She is looking to spend in the $150-$180 range, any suggestions?
Any help would be much appreciated, thanks in advance
Unless you have a PC with a DVD burner and the correct software, editing of commercials is going to need an HDD-equipped unit.
The price point you speak of, while it contains many good non-HDD units (Panasonic ES10, Pioneer 220/225), is pretty hard to find a good HDD equipped unit. You might be able to locate a no-name Chinese made model for that price, but I wouldn't recommend them, and neither would most members.
A possibility is to record on DVD-RW(VR) and edit on those. You won't be able to play these on older players, but many newer players (including the sub-$100 models) will play VR mode discs. Note that this will eliminate the Panasonic recorders, as none do VR mode on -RW discs and all but the latest don't even do -RW at all, only -RAM which pretty much requires a Panasonic player.
If there is a Good Guys store in your area, they are blowing out the remaining Pioneer DVR-520H's for $299. That's about as cheap as you'll get for a recommended HDD model.
Discussion Starter · #3 ·
I have an older computer and do not have a DVD burner on it. I am afraid if I put one on, and try to get editing software, that it won't work with it.
Am I probably just better off getting a good non- HDD unit, and dealing with the commercials?
How about copying the DVD movie collection for friends and family? Does the Clarifier work well for getting around copyrights?
This reminds me of my first DVD recorder purchase in May 2002. The Panasonic DMR-E20 complete with black level bug and NO hard drive. It recorded to DVD-RAM and DVD-R only. Couldn't play MP3 discs. I picked one up for the incredibly cheap price of...(drumroll please)...$599. Hey at least it had a black case.
Supposedly you can copy a commercial DVD movie from player thru the Sima CT2 video enhancer into a DVD recorder. Do a search in this forum for Sima. Or go to a local Best Buy where they sell them for advice.
However, my best advice, if you have a newer computer with a DVD burner is to download DVD Decrypter and Shrink (both free) and use your computer to do all the work. Or buy Nero 6 or Roxio EMC 7.5 software. That's the way I do it.
vferrari... don't feel sad about the price. I paid $650.00 for my first VCR with wired remote. Tapes were $13.50 each. But, they gave me a $2.00 discount because I had just bought the machine. At the present time RW discs are cheaprer then VHS tapes.
Discussion Starter · #6 ·
I ended up picking up a Magnavox MRV640 at Best Buy open box for $109. It has +RW disc write, and you can edit those and make the commercials into hidden chapters, so that you don't watch them on playback
Will probably pick up a CT-2 off Ebay with my birthday money for recording my DVD collection
Just got my daughter the Sima CT-2 & she told me she copied "Shreck 2" (For use in her car & laptop) with no problems at all. She then played the original back & her copy back at the same time switching between the two & she said that the copy was just a little softer but not bad at all & she had been checking for "Brighter," "Darker," or "Lines" in the picture but she said she could not find any "Black Level Bug" in the CT-2 as it's reported to have but maybe it will show up in other movies? If you want perfect copies though with original menus & Dolby 5.1 Audio & etc the only way to do that is with a computer but my daughter din't want to go that route & she also has her VCR tied into the loop using the CT-2 so she can dub her Video Tapes to DVDs too. I would give the Sima a shot & if your not sure of it buy it from Best Buy or Circuit City so if your not happy with it you will have no trouble returning it.
1 - 7 of 7 Posts
Status
