I’m a complete newbie, I got a deal on an Infocus 720 which needed a new lamp, which I installed today. I’m quite happy with it except for several green and red spots clearly visible on a black screen. I’m not quite sure what the problem is and wanted to know if it’s a simple fix or just something I’ll have to put up with. Here are my observations.
If you focus on these spots you can see they appear as little green/ red threads. They are on a different focal plane than the projected image..
If you invert the image these threads/ spots do not move.
It looks like the previous lamp had exploded, in fact there was a loose piece of glass in the case, I had to shake the unit to remove it…
Could this be dust as that was my impression, and if so how would I go about removing it? Could they be scratches from the loose piece of glass? I have a feeling if it would be in the “non-user serviceable†area which I am a little reluctant to do at this point……
I don’t know how I went without one of these all those years, I can ignore those spots but if there is a way to get rid of them all the better! I’m sure there is a simple answer but at this stage I’m not sure what it is………
Any help would be greatly appreciated… http://www.avsforum.com/ubb/smile.gif
JON
JON
