Status
Not open for further replies.
1 - 2 of 2 Posts
Premium Member
Settled on the SOny 40in. Has HDTV etc. Currently have dish with dual LNB. Figured out I need to upgrade to an eliptical dish with QUAD LNB. Only have one HDTV - so assume that the other tv's will run at whatever they do today.
? - Do I need a HDTV receiver if the SONY has 1088i?
? - If I need a receiver, should I just look for a package for the receiver/dish etc?(Have read abouth the zenith, most places offering hughes)
? - To run the other tv's - assuming i need a receievr, can i use a non hdtv receiver for the other sets like I do today?
Therese
Setup will be a denon 5803 receiver, Sony 40in WEGA, DIVA 6.1's etc, Sonance 260 amp - still dont know dvd yet, sony megechanger
It's actually two dual LNB's. If you want Showtime HD, you add the Sat-C kit to it.
If there is no DirecTV HD receiver built into your TV, then you need an HD receiver.
Yes you can.
-Robert
1 - 2 of 2 Posts
Status
