Status
Not open for further replies.
1 - 3 of 3 Posts
Hello all,
I need some help getting that right plasma. Looked at Bestbuy over the weekend and liked the picture on the Sony ke-42ts2. Did a search here and sounds like the "gurus" don't like it.
I have around 6k to spend. What would you get?
Thanks in advance,
Josh
1) Take your time to research the various brands and models. A good start is to read the FAQs on this forum which cover many of the most popular models. One specific recommendation I would make to you is to make sure you get a plasma that either has DVI/HDCP, or can be upgraded to provide DVI/HDCP.
2) Understand that most forum members will be parochial. They will unhesitatingly recommend what they purchased. That is not all bad since it indicates that they are satisfied with their purchase, BUT they are still biased. For example, I love my Pioneer 433-CMX and would buy it again in a heart beat.
3) Winnow down your choices and try to compare the models you like, viewing the same sources (SDTV, DVD, HDTV) on each.
4) Pick what your eyes tell you is the best.
5) Enjoy your plasma and don't look back.
1 - 3 of 3 Posts
Status
