I have been reading posts on this site for a few days and I am impressed with the amount and depth of knowledge demonstrated in all of the fora – I’ve learned a lot already. I’ve got a few embarrassingly newbyish questions, however, that haven’t been addressed in any of the posts I’ve read or any HT FAQs that I’ve seen.
I’m looking to set up a front projection system in my finished basement for my teenage kids to use. Based on current usage, I would guess that it would be used about 70% for PlayStation2, 15% TV (cable), and 15% DVD. The basement is 18’ by 25’ with a drop ceiling that is mostly 6’ 9†high. The setup is somewhat complicated by posts and ductwork that may make a ceiling mount difficult, and is also complicated by the fact that the boys like to roughhouse with friends and play indoor soccer and football down there, so any HT setup would have to be either tucked away at the side of the room or able to be closed into a cabinet and any furniture would have to be on wheels.
1). All the posts about FP setups seem to talk about ceiling mounts. Is it possible to do a decent setup with the projector in a cabinet or rack on the floor? Would the projector have to be very low to the ground in order to get the maximum picture height?
2). I hope to just use a wall to project against. Is that reasonable to do, or do I need to have a screen? Is there any special color or type of paint that I would use on the wall to make the picture look better?
3). I plan to route all of my inputs (VCR, DVD, PS2) into a receiver and connect the receiver to the surround sound speakers and the projector.
a). Where does my TV cable plug into and what do I use as a TV tuner? Do I need a cable box, do I just use the VCR as a tuner, or should I get something like a TiVo? What happens when I want to start into HDTV?
b). When I hook up cables to the projector, do I just use the highest-quality connection available from the tuner to the projector, or do I need to hook up every available tuner output to every available projector input?
Those are the things that are mystifying me at the moment. I appreciate any help that anyone can give me.
