Hey guys, I have a new home built a couple months ago that was pre-wired. But that's ALL they did, run the wire. I've attached a pic of the control box in the garage. You can see all the blue eithernet wires just sitting there. All the black wiring is Comcast's. I have NO idea what to do here. I'm close to calling a professional installer but I really don't want to pay a bunch for something if I can do it myself. I hate anything to do with networking though. At my last house I had everything going over wifi and that was a nightmare so I really want to use the ethernet wiring. I need help with the control box for sure but once that's done, here's what I want to do. Let me know how this looks.
Family Room:
The family room will have the modem, router, Comcast DVR, Wii U, Sonos Bridge, and Apple TV. It has 1 ethernet port wired. So would I hook the modem up to the router, the router to the wall, the router to a switch and then plug everything else into the remaining ports on the router and then into the switch or everything else just into the switch?
Room 1:
Room 1 has a PC, PS3, PS4, Xbox 360, Xbox One, Apple TV and Phillips Hue Bridge. So in this room I would connect a bridge to the in wall ethernet and then everything else into the bridge? And that will be a good connection between the computer and Apple TVs? I use iTunes to stream to my Apple TVs and that was a giant nightmare over wifi.
Room 2:
Room 2 doesn't have anything that needs to plug into the ethernet but it's on the opposite diagonal side of the house from the modem in a 2,700sqft single story so the wifi on my iPhone and iPad is rough. I can plug another modem into that ethernet jack and extend the wif to that room, correct? And it does have an iMac but for what I do on it, wifi is fine. If I wanted to go ethernet on the iMac though, I would just plug the extra router into the wall, then the iMac into the router, correct?
And that's it really, everything else are wifi devices. But every room does have an ethernet jack so for future reference, if I wanted to, could I plug a swtich into every single room? When do you have too many switches?
Also I currently use an Airport Extreme, the older version that isn't gigabit. So a recommendation on the main router and the extension router would be appreciated as well.
Family Room:
Room 1:
Room 2:
