Status
Not open for further replies.
1 - 2 of 2 Posts
Hi all,
I just wondering what do you guys do for cooling inside of the case ? There is no case fan mounting holes anywhere inside the case that can be installed with any case fans.. What CPU are you guys using ? Is heat an issue to you ?
I bought the Nexus case and getting ready to set it up. Just couldn't figure out where can I mount the case fans to... I am setting up my AMD XP 2500+ and going to OC to 3000+ or higher, so not sure if the tempature will be tolerable without any case fans ?
Many thanks.
well, i'm a complete n00b when it comes to building PCs... my HTPC will be the first PC i build from scratch, and my first P4 as well. i have the Nexus case, and noticed that on the left wall (when you're facing the front of the PC) there's two threaded posts sticking out where the vent is cut. i figured that's where the exhaust fan is supposed to go, but i could be wrong.
they really need to supply better assembly instructions with this case. illustrations wouldn't hurt.
1 - 2 of 2 Posts
Status
