1 - 8 of 8 Posts
· Registered
I just built the PC and connected it to jvc rx-d702 b through hdmi on ati hd 5850. In windows 7 i am configuring sound in in sound panel. I enabled ati hdmi sound in there but i only get 5.1 speaker configuration. I have the newest drivers from ati website.
Does anyone know how to enable 7.1 sound in windows 7. I want to test it before i go ahead with other htpc configurations.
Thanks in advance
· Registered
If you're bitstreaming, I don't think it makes a difference if it is set to 5.1 or 7.1. I could be wrong but I have an Asus HDAV 1.3 and my output device is set as spdif. When I play a BD with 7.1, I get 7.1 from my receiver. Same for a 5.1 source.
· Registered
You should set up bitstreaming first. Once that is working, everything else should work as well.
Once I had bitsreaming of DTS-HD, TruehHD, DD, and DTS working in TMT3, everything else worked fine. I got DD 5.1 in MCE and 2.1 in iTunes without further changes. My receiver lights up according to the signal it is receiving (stereo, 5.1, 7.1) even though Win7 says I have 5.1 speakers.
If you are connecting via hdmi to your receiver and then to your tv, your video card should be picking up the edid from your receiver. Is that happening?
· Registered
Discussion Starter · #5 ·
This is what i get. I am using a projector and jvc receiver is set up with 7 speakers. no sub.
I am not sure how to read it but it does not say anything about speakers configuration here.
does that tell you anything?
EDID ( Extended Display Identification Data) Report
Vendor/Product Identification:
Monitor Name : RX-D701
Monitor Serial Number :
Manufacturer Name : JVC
Product Id : 6101
Serial Number : 16843009
Week Of Manufacture : 0
Year Of Manufacture : 2005
EDIDVersion : V1.3
Number Of Extension Flag : 1
Display parameters:
Video Input Definition : Digital Signal
DFP1X Compatible Interface : False
Max Horizontal Image Size : 0 mm
Max Vertical Image Size : 0 mm
Max Display Size : 0 Inches
Power Management and Features:
Standby : Not Supported
Suspend : Not Supported
ActiveOff : Not Supported
Video Input : 1
sRGB Default ColorSpace : False
Default GTF : Not Supported
Prefered Timing Mode : True
Gamma/Color and Etablished Timings:
Display Gamma : 2.2
Red : x = 0.649 - y = 0.342
Green : x = 0.326 - y = 0.649
Blue : x = 0.139 - y = 0.05
White : x = 0.284 - y = 0.334
Etablished Timings :
640 x 480 @ 60Hz (IBM, VGA)
Display Type : RGB Color Display
Standard Timing:
Preferred Detailed Timing:
Pixel Clock : 74.25 Mhz
Horizontal Active : 1920 pixels
Horizontal Blanking : 280 pixels
Horizontal Sync Offset : 88 pixels
Horizontal Sync Pulse Width : 44 pixels
Horizontal Border : 0 pixels
Horizontal Size : 708 mm
Vertical Active : 540 lines
Vertical Blanking : 22 lines
Vertical Sync Offset : 2 lines
Vertical Sync Pulse Width : 5 lines
Vertical Border : 0 lines
Vertical Size : 398 mm
Input Type : Digital Separate
Interlaced : True
VerticalPolarity : True
HorizontalPolarity : True
Detailed Timing #2:
Horizontal Blanking : 720 pixels
Horizontal Sync Offset : 528 pixels
Interlaced : True
Monitor Range Limit:
Maximum Vertical Frequency : 61 Hz
Minimum Vertical Frequency : 50 Hz
Maximum Horizontal Frequency : 49 KHz
Minimum Horizontal Frequency : 28 KHz
Maximum Pixel Clock : 80 MHz
Stereo Display:
Stereo Display : Normal display (no stereo)
RAW Data:
0x00 00 FF FF FF FF FF FF 00 2A C3 01 61 01 01 01 01
0x10 00 0F 01 03 80 00 00 78 0A 69 BE A6 57 53 A6 23
0x20 0C 48 55 20 00 00 01 01 01 01 01 01 01 01 01 01
0x30 01 01 01 01 01 01 01 1D 80 18 71 1C 16 20 58 2C
0x40 25 00 C4 8E 21 00 00 9E 01 1D 80 D0 72 1C 16 20
0x50 10 2C 25 80 C4 8E 21 00 00 9E 00 00 00 FC 00 52
0x60 58 2D 44 37 30 31 0A 20 20 20 20 20 00 00 00 FD
0x70 00 32 3D 1C 31 08 00 0A 20 20 20 20 20 20 01 49
· Registered
Discussion Starter · #6 ·
A step closer.
i found moninfo and it reports only 5.1 sound configuration.
Now i need to fix it somehow. Any info greatly appreciated.
Monitor
Model name............... RX-D701
Manufacturer............. JVC
Plug and Play ID......... JVC6101
Serial number............ n/a
Manufacture date......... 2005, ISO week 0
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. Undefined or variable
Power management......... Not supported
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.649 - Ry 0.342
Green chromaticity....... Gx 0.326 - Gy 0.649
Blue chromaticity........ Bx 0.139 - By 0.050
White point (default).... Wx 0.284 - Wy 0.334
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 28-49kHz
Vertical scan range...... 50-61Hz
Video bandwidth.......... 80MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #1....... 1920x1080i at 50Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2448 2492 2640 1080 1084 1094 1124 interlace +hsync +vsync
Standard timings supported
640 x 480p at 60Hz - IBM VGA
EIA/CEA-861 Information
Revision number.......... 3
IT underscan............. Not supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 1
Detailed timing #1....... 720x480p at 60Hz (4:3)
Modeline............... "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
Detailed timing #2....... 720x576p at 50Hz (4:3)
Modeline............... "720x576" 27.000 720 732 796 864 576 581 586 625 -hsync -vsync
Detailed timing #3....... 1280x720p at 60Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Detailed timing #4....... 1280x720p at 50Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1720 1760 1980 720 725 730 750 +hsync +vsync
CE video identifiers (VICs) - timing/formats supported
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
1920 x 1080i at 50Hz - HDTV (16:9, 1:1)
1280 x 720p at 60Hz - HDTV (16:9, 1:1) [Native]
1280 x 720p at 50Hz - HDTV (16:9, 1:1)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
720 x 576p at 50Hz - EDTV (4:3, 16:15)
640 x 480p at 60Hz - Default (4:3, 1:1)
1440 x 480p at 60Hz - DVD (4:3, 4:9)
1440 x 576p at 50Hz - DVD (4:3, 8:15)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48/88/96/176/192 kHz
LPCM 6-channel, 16/20/24 bit depths at 32/44/48/88/96 kHz
AC-3 6-channel, 448k max. bit rate at 32/44/48 kHz
DTS 6-channel, 1536k max. bit rate at 32/44/48 kHz
CE speaker allocation data
Channel configuration.... 5.1
Front left/right......... Yes
Front LFE................ Yes
Front center............. Yes
Rear left/right.......... Yes
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 1.1.0.0
Supports AI (ACP, ISRC).. Yes
Supports 48bpp........... No
Supports 36bpp........... No
Supports 30bpp........... No
Supports YCbCr 4:4:4..... No
Supports dual-link DVI... No
Maximum TMDS clock....... 165MHz
Report information
Date generated........... 11/21/2010
Software revision........ 2.53.0.861
Data source.............. Real-time 0x0021
Operating system......... 6.1.7600.2
Raw data
00,FF,FF,FF,FF,FF,FF,00,2A,C3,01,61,01,01,01,01,00,0F,01,03, 80,00,00,78,0A,69,BE,A6,57,53,A6,23,
0C,48,55,20,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01, 01,01,01,1D,80,18,71,1C,16,20,58,2C,
25,00,C4,8E,21,00,00,9E,01,1D,80,D0,72,1C,16,20,10,2C,25,80, C4,8E,21,00,00,9E,00,00,00,FC,00,52,
58,2D,44,37,30,31,0A,20,20,20,20,20,00,00,00,FD,00,32,3D,1C, 31,08,00,0A,20,20,20,20,20,20,01,49,
02,03,26,71,49,05,14,84,13,02,11,01,0E,1D,2C,09,7F,07,0D,1F, 07,15,07,38,3D,07,C0,83,0F,00,00,66,
03,0C,00,11,00,80,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,00,13,8E, 21,00,00,18,8C,0A,D0,90,20,40,31,20,
0C,40,55,00,13,8E,21,00,00,18,01,1D,00,72,51,D0,1E,20,6E,28, 55,00,C4,8E,21,00,00,1E,01,1D,00,BC,
52,D0,1E,20,B8,28,55,40,C4,8E,21,00,00,1E,00,00,00,00,00,00, 00,00,00,00,00,00,00,00,00,00,00,96
· Registered
Discussion Starter · #8 ·
sorry for the delay. both my work and home computer need fixing. So I am final back to the HTPC.
My receiver reports multichannel PCM. thats about all I can tell. It also shows channel icon for the channels it is receiving.
I went through the guide and installed shark decoder and checked pass through. Is there anything else i need to set. I am still reading the guides. I downloaded 7.1 channel wav file and it only plays in 5.
I also modified the edid. I changed number of channels only, nothing else. It now reports 8 channels (7.1) but the receiver only displays 5 and when i do sound test from windows it only plays 5 speakers. no side ones. i am not sure if i set the frequencies correctly or channels. this is my updated edid.
any ideas whats wrong?
Monitor
DDC/CI................... n/a
LPCM 8-channel, 16/20/24 bit depths at 32/44/48/88/96 kHz
DTS 8-channel, 1536k max. bit rate at 32/44/48 kHz
Channel configuration.... 7.1
Rear left/right center... Yes
Report information
Date generated........... 11/25/2010
Data source.............. File
Raw data
02,03,26,71,49,05,14,84,13,02,11,01,0E,1D,2C,09,7F,07,0F,1F, 07,15,07,38,3F,07,C0,83,4F,00,00,66,
1 - 8 of 8 Posts
