I was able to capture @640x480 with audio using I/O Magic and AP2496. After I did a fresh install on a P4B266 with on-board audio (c-media) and win98se, I can only capture @320x240, any resolution higher the capture screen will freeze. I can hear the audio while recording from s-video and composite, but on playeback, no audio.
In PowerVCR, the audio recording is set to line-in and i have tried SW sync and WAV file type with no luck. I have reinstall PowerVCR, c-media audio, Btwin capture drivers several time with no improvement.
So what cause the drop in capture resolution? Do I need a separate audio card to fix the no audio problem?
-JL
-JL
