1 - 3 of 3 Posts
I have just setup my win 7 media center with my New htpc. I am using avermedia g2 tuner card. However, when I finished setting up all the channel, there is no guide for all my local HD channel. When I go to zap2it, I can see that there is guide for those channel. I have tried to ask MC to update guide several time to no available. Can anyone please help???
first you need to make sure that the channel is mapped to the right guide data. you can do this under the edit channel option in the setup.
What is your TV source to the SD analog tuner connector on your G2 card?
What is your TV source to the HD digital tuner connector on your G2 card?
It appears that you may have only set up only the analog tuner in MC.
1 - 3 of 3 Posts
