Status
Not open for further replies.
1 - 5 of 5 Posts
Hello
I went to use my 4500 replay today and it came up no channel guide.
I use my 243 Zone button hit NET CONNECT it initalizes my modem hooks up with replay server and blast thru new channels in 1 min then does all the rest and shuts off. NO channel guide still.
On the Channel guide page it says " NO CHANNEL GUIDE INFO AVAILABLE. PLEASE CHOOSE SETUP FROM MAIN MENU. SELECT NETWORK & INPUT SETTINGS TO UPDATE CHANNEL GUIDE"
I go to update settings and it is looking for network info.
it wants
IP Address
Subnet mask
gateway
DNS server 1
DNS server 2
I DO NOT HOOK UP USING THE INTERNET I HAVE A MODEM.
I can not proceed with anything else
CAN ANYONE PLEASE HELP ME
THANK YOU
Greg
Haven't gone through the menu in a long time on a 4xxx series. However, when you go into the "Select Network and Input Settings" menu, can you choose something like "switch to modem" ? If so, that's what you need to do.
You might want to try deleting channel guide using 243 zones or restoring to factory default using 382 zones screen. If you do the later you lose all recordings and setup data.
1 - 5 of 5 Posts
Status
