I wanted to use my tv's remote to control the volume on the vsx-21. The same remote
had the right codes for my old Yamaha, but no codes for Pioneer that work.
I've got a harmony remote, but I can't stand those things. Always turning things off that
should be on or vice versa. Always chosing the wrong inputs. The communication with
my computer is sooo slow that I've spend hours getting no where. I'm done with macros.
Is there a way to get an old remote to learn the codes to a new receiver?
Just want to control volume/power/input if possible.
Mitsubishi WD-65732 is the tv.
Pioneer vsx-21 is the receiver.
Thanks in advance if anyone has a solution.
