Hi folks!
My HD-A30 was at firmware 1.3/1.1 and worked semi-ok. After I tried playing a couple of SD disks that suffered from cascading pixelation and malfunctions, I upgraded the firmware to version 2.0 (I didn't notice that 3.0 had come out when I upgraded). After the upgrade to 2.0, which was successful according to the version screen, I was no longer able to read any Standard Definition disks again. HD-DVD disks worked fine, but nothing SD at all.
I did some reading and found that firmware version 3.0 was out, so I upgraded to it (I had to use the ethernet to do it since it would no longer read CD-Rs either). The upgrade to version 3.0 was successful as well, but it still can't read SD disks.
The symptoms are that "loading" stays on the display for around 30-40 seconds or so, then "No Disc" appears on both the display and the screen. While "loading" is on the display, unusual noises emit from the drive - not loud, but you hear alot of clicks and clunks.
HD-DVD disks still work perfectly fine. Does anyone have any advice about how to get SD support back? I would try downgrading to 1.3 again, but I think (but haven't thoroughly tested yet) that I may be unable to read CD-Rs still, and as such will be out of luck.
Any way to reset it to back to scratch?
Also, I've seen alot of posts that say that they have firmware 3.0/T23T. The latter part is the "engine" firmware, right? I vaguely remember updating it when I first got the player to 1.1. Anyone know if T23T is available anywhere? If it's available, could it help in this case?
-Keith
-Keith
