If I play a DVD with WinDVD 5 Platinum LFE effects are sent to the subwoofer correctly, when 'Send 0.1 effects to front channels' is ticked in the Audio WinDVD subpanel.
If I play a DVD with ZoomPlayer and the WinDVD audio filter then LFE effects are not sent to the subwoofer. Blight would it be possible to add this to Zoom Player under External settings?
I ran regmon and found that WinDVD sets the registry setting for SUBWOOFER to 1. I tried making a new key under HKEY_CURRENT_USER\\Software\\InterVideo\\Common\\AudioDec but this didnt help!. So there does not seem to be any registry setting that works in Zoom Player when your using just the WinDVD audio filter
