1 - 17 of 17 Posts
I finally got around to calibrating my 60ST60-which IMHO turned out great and looks spectacular.
The one thing I found odd was that I did not need to adjust luminance/Y of any of the primaries.
Is my set perfect or did I miss something??
Screen shots of Calman below.
Be happy with your set. The measurements looks very good. To be sure, not only 100% saturation points are good, you may run ColorChecker and saturation / luminance sweeps. This gives you more objective view how is your set inside color gamut i.e. like viewing real content.
  • Like
Reactions: ConnecTEDDD
Discussion Starter · #3 ·
Thanks that's a good idea.
I would say that when viewing much of the content looks great in all aspects but is under saturated.
Will report back after I run colrchecker and sweeps.
Discussion Starter · #5 ·
Originally Posted by randal_r  /t/1524774/no-need-to-adjust-luminance-y-on-panasonic-60st60-plasma#post_24547764
Hi,
I have been looking at the "Y" values vs. the Target "Y" values and I am bewildered as to why your color chart (Red though to Magenta) would illustrate such results. I have a feeling that it might be a hardware issue. I would like to make a suggestion. Try to redo a calibration in another video mode; Standard vs Cinema. See if the results are the same. All in all, by the numbers you have done a excellent job. By what I see you should have near perfect Brightness / Contrast and no Gamma issues. Another thing that comes to mind is "do you have all of the auto features turned off"? Recheck.
Good luck.
Thanks for the info, I will give another calibration after I run colorcheker and sweeps.
All enhancements were turned off.
Are you calibrating color at 100% saturation, the ST60 color calibrates best at 75/75 in my experience.
Originally Posted by chunon  /t/1524774/no-need-to-adjust-luminance-y-on-panasonic-60st60-plasma#post_24551011
I agree 75% amplitude and 75% saturation.
Discussion Starter · #8 ·
Originally Posted by hungro  /t/1524774/no-need-to-adjust-luminance-y-on-panasonic-60st60-plasma#post_24553625
I'm using the smallest AVSHD APL Calman windows at 75%.
Originally Posted by trans_lux  /t/1524774/no-need-to-adjust-luminance-y-on-panasonic-60st60-plasma#post_24557005
You should use GCD or Mascior's Calibration Disk. Gamut Calibration Disk has the patterns you need.
Originally Posted by hungro  /t/1524774/no-need-to-adjust-luminance-y-on-panasonic-60st60-plasma#post_24557725
The Mascior disc is not 100% compatible with calman, there are some triplet differences since it was designed to be used with chromapure. I would stick with GCD
Be sure to check use constant luminance with saturation sweeps in Calman 5 when using the gcd disc. It's under work flow advanced.
Discussion Starter · #15 ·
Originally Posted by PlasmaPZ80U  /t/1524774/no-need-to-adjust-luminance-y-on-panasonic-60st60-plasma#post_24560001
Thank you will do.
Can you explain why this is correct/beneficial, only for plasma?
Originally Posted by chunon  /t/1524774/no-need-to-adjust-luminance-y-on-panasonic-60st60-plasma#post_24559747
Oops, i forgot one is for Chromapure and the other is for Calman. Like Chunon said stick with GCD. I use Chromapure personaly.
Originally Posted by trans_lux  /t/1524774/no-need-to-adjust-luminance-y-on-panasonic-60st60-plasma#post_24561073
Thank you will do.
the rgb triplets for the gcd are different from the CMD HD disc and Ted's disc and so the use constant luminance with saturation targets lets Calman 5 know that.
1 - 17 of 17 Posts
