Status
Not open for further replies.
1 - 3 of 3 Posts
Just discovered the component inputs of the X1 only takes a interlaced signal and I can only get progressive through the VGA. However my Xbox has no VGA, I only have Component cables. Is the only way to get progressive on the X1 to use a Computer because that would suck. I am assuming the Sony HS10 for examples has component video inputs that support even HDTV right? And how about 1080i? Because as I undertsand it the X1's component ports do not go higher than 480i? or is there some VGA to component adapter you can buy so that the infocus X1 vga port can be used with component cables?
Anyone have any ideas on this?
1 - 3 of 3 Posts
Status
