1 - 4 of 4 Posts
· Registered
Hi I have JVC D702B Receiver with Definitive Speakers. The front speakers and the Sub woofer works fine but there is no sound from the center and the rear speakers. When I try testing the speakers, all the speakers work fine.So the connection is fine. But there is no sound from the rear and center speakers while playing TV or DVD Player.
Would appreciate your help.
· Registered
So your choosing PLIIx on the receiver when watching TV or DD/DTS when watching a DVD?
And you've selected 5.1 on the DVD menu before playing?
· Registered
Well, then....I'm at a bit of a loss.
Does the receiver light up Dolby Digital or DTS when you're playing a DVD? Have you calibrated all your speaker levels? (I know, long shot) And how is everything connected to your receiver as regards to sound, optical or coax?
1 - 4 of 4 Posts
