Status
Not open for further replies.
1 - 3 of 3 Posts
I have the Dish Network 6000 receiver connected via component video to a Pioneer Elite HDTV 710 Pro and to a Denon 5800 via optical audio connection. I can hear sound on all channels except the HDTV Demo channel and the Showtime HDTV channel. The picture is great but no sound. What am I doing wrong?
Farid
Sounds like you're not getting audio only on the true DD broadcasts.
Go into the 6000's setup Menu under Dolby Digital...and make sure Dolby Digital/PCM is chosen as opposed to PCM only.
Then make sure your Denon is set to something like Auto..for that input. Or whatever setting definitely recognizes DD.
Dan
Mitsubishi 55805
Dish 6000
DirecTv/Mitsu SR-HD400
Evu 6000
[This message has been edited by DP1 (edited 09-28-2001).]
Discussion Starter · #3 ·
Thanks a million. I couldn't have figured this out in a 100 years. My Denon 5800 was set to PCM. I switched it to Auto and got sound on the HD channels.
Farid
1 - 3 of 3 Posts
Status
