1 - 7 of 7 Posts
Discussion Starter · #4 ·
Is it possible it changed inputs? If all else fails go through setup menu again . Good luck
I have tried that, and every other thing I could think of. I went back through the manual and can't figure it out. On my old Denod it would channge surround parameters. I was hoping someone might have an idea before I reset it.
I think a reset is probably your best option. You saved your last good config file with the web interface, right?? ;)
If not, it's a good habit to get in to.
Discussion Starter · #7 ·
No I haven't, still a lot to learn about this unit. I did figure it out. Input mode was switched to analog, I switched to auto. I don't know how one button on my dish remote did that.
Thanks guys!
1 - 7 of 7 Posts
