Status
Not open for further replies.
1 - 6 of 6 Posts
Anyone hear about this problem? Also how do I check the version of the software on my TV, it is model IQB64W10W. I get no sound just on this station. What am I doing wrong?
Thanks for any help!
Patrick
Patrick Rogers
A lot of messages have been posted about the same problem with some New York stations.
You might want to check them (I think one of them listed the encoding equipment causing the problem.) The Zenith seems to be most sensitive to the problem, but it CAN be corrected at the transmission end.
Rick
Patrick,
I had this problem for quite a while with one station, WPLG-DT in Miami, on my IQB64W10W. If you press the "info" button on your Zenith remote while tuned to the offending channel, under the heading, "Language:" you will probably see "Unknown." On stations that you do get sound on you should see "English," or whatever language a particular station broadcasts in. I used to get "Unknown" along with no sound on WPLG-DT until they altered settings on their ATSC encoder. This restored sound and under "info" on the Zenith under "Language:" it said "English."
HiDefDave
STOP HDCP!
Patrick...are you still having problems with Seattle KING5 (NBC) digital channel? I've got a Zenith IQB56W10G (56" version of your set) and have the same issue!!
-Shan-
I have a DTC-100 and although KING-DT (Seattle) is broadcasting channel information (I don't remember what the term is), my sound is cutting on and off (mostly off). I am getting no picture and the display (channel info) flops between 4:3 and 16:9. The signal strength hasn't changed.
Seems the new channel info is causing the problem.
I just checked my Mits HD-SR5 and Panasonic TU-DST50 and King's demo loop is rolling right along with no problems at my place.
Rick
RJW
1 - 6 of 6 Posts
Status
