1 - 3 of 3 Posts
Hi all,
I have been running a SR6005 for about a year or so and just installed some outdoor speakers and connected them to the Zone Two speaker output. I am running it with a BD player (connected via HDMI) and when playing a CD, I get no sound. I then tried the internal tuner and still get no sound from Zone 2.
Any ideas would be apprecaited. Thanks!
You have to use an analog connection for zone 2 sound. HDMI doesn't work there, nor do optical or digital coax.
Connect a pair of stereo audio cables (red/white RCA jacks) from your BD player to the BD or CD input on the back of the Marantz. Then when you select that input for zone2 you will hear sound.
The internal tuner should work as long as your using Zone 2 properly.
Please read pages 45 - 46 of your owner's manual to configure zone 2. If you no longer have the manual you can download it here.
http://us.marantz.com/DocumentMaster/US/SR6005_U_EN_UG_v00.pdf
The surround back channel amps also must be assigned to Zone 2.
1 - 3 of 3 Posts
