1 - 2 of 2 Posts
This has been an intermittent problem that I have never quite nailed down the cause. The audio through the hdmi does not work sometimes, and is currently not working. I have confirmed this through all 3 hdmi jacks using two different sources (apple tv and panasonic blu ray). The issue seems to have restarted when I turned off the apartment power to install a light fixture and turned the power back on. That leads me to believe it might be some setting that got lost or confused. However, other times it seems to have happened when I wiggled or unplugged/replugged the hdmi cables- that leads me to believe it might be a bad solder joint or connection.
Has anyone ever had a similar issue?
1 - 2 of 2 Posts
