Status
Not open for further replies.
1 - 7 of 7 Posts
· Registered
Hi
I have no problem recieving ATSC with OTA anttenna but....
When i hook up the cable straight to PC i get no sound.
I have the QTA antenna in input 1 (ATSC)( no problem here)
I have the cable in input 2 and checked it for cable. (no sound)
Right now i'm just using 2 pc speakers which work fine with the ATSC sound but nothing when i switch over to NTSC.
Still learning...
Thankyou kindly
Bluerain
"Soon my friend,Soon...."
· Registered
BlueRain,
Did you post this in the Home Theater Computer forum? I know when I built my HTPC I had alot better luck in there with the computer questions for you. Hope that someone helps you out with an answer! Good Luck!!
Peter L.
· Registered
Discussion Starter · #4 ·
Peter,
Thanks for replying anyway.
I'll leave it here for a day and see what i catch, if nothing i'll try there.
· Registered
Bluerain,
Do you have the speakers connected directly to the analog audio out of the HiPix daughter card or to the analog output of your sound card?
Carl
· Registered
Discussion Starter · #6 ·
Carl
I have it connected to my sound card that's the way figure 6 shows it(instructions)
I'll try connecting it Expansion card.
Thanks so much Carl http://www.avsforum.com/ubb/smile.gif
PS: The picture (cable) looks bad , some almost look scrambled. Works fine on my TV,any suggestions for this?(pc cable pic)
Bluerain
· Registered
Although I no longer have the HiPix, I can tell you that analog (NTSC) reception is not the strength of the card. In fact it is quite poor.
As to NTSC sound, that is only available (as I recall) from the analog outputs. You will get no cable (NTSC) sound from the digital output.
Jeff Hipps
1 - 7 of 7 Posts
Status
