Since I have had my HT I have always had the gains on my EP4000's maxed and I control the level with the SW control when needed. I almost always watch live stream now so the SW level is always maxed at +12dB and the receiver is usually MV -20dB. Rarely a really quiet movie I will have to turn it up to -15dB but mostly I turn it down to -25dB. My mains usually seem pretty quiet unless I listen very closely I can maybe hear a slight faint hiss... nothing out of the ordinary. If I turn it up to -10dB or even 0dB MV then of course I get loud hiss. But the subs always seem to be making noise when I am at -20dB. I know if i turn the gains down it will go away but then I wont have enough. When I used the BFD for a while, it amplified this noise. When i was trying to do large boosts and cuts it amplified the noise so much there was visual cone movement as well as loud rumble at whatever frequency range I boosted heavily. I run all HDMI, I havn't used the Bluray player in months, just the PC. The more I turn the receiver volume down, the quieter the noise... if I turn it down to -60dB there is no noise... so it's not like it is induced in the line after the receiver or simply too much gain...its like it is the receiver or the signal going to the receiver has noise that it amps. When I shut my TV off, the receiver does its auto detect flash... there is a dull pop as it shuts off for a second, the noise is gone, then a dull pop as it comes back on and the noise is back. Same with the PC, when i mute the PC it goes completely silent for a second...the receiver detects the absence of input...then it clicks and their is noise again, while the PC is still muted. When i unmute, there is a click, complete silence, another detection click, then noise. Turning the SW level down does the same thing as MV.
So where does the noise come from? If I was using RCAs I could understand it...but this is digital?
