Status
Not open for further replies.
1 - 8 of 8 Posts
posted in another section of this forum too.........was told this is a better spot, sorry for double post fellas!! I need help though!!
hi guys im new to this forum........and to HD tv itself so forgive me if i say something stupid or post in the wrong spot. Here goes, i already asked this question on another forum and didnt get much help other than being told to come here because this forum is good. I will paste what i posted so i dont have to re-do it all.........can anyone help me?
*****hey guys, im new to this HDTV thing.......was wondering if i could get some help here. I have a p4 2.5, with a g4 ti4400 dvi out........i ran it from the card to the back of my sony 65" HD that i just got this weekend and it works OK but seems like it could be sharper for an HD. My desktop has icons that go off screen, and half my taskbar is hidden. No matter what i set my resolution too, i cant get it right. I kinda read up on this power strip thing but dont know if im reading into what im looking for.
PLEASE PLEASE can someone give me a step by step of how i can do this the right way so i can get the most out of using this for a monitor? (its fun to surf in the living room!)
***this tv is a Sony - KP65WS510 has anyone had luck with this? i want the computer to look good on it, i really just need step by step instructions. Ive read TONS of posts but i am still kinda confused........seems like if i didnt find my specific TV i am not doing something right. I already downloaded powerstrip and after changing a few things around i had a close call with disaster......but i got it back now. I have a yahoo messenger acount and i go by the name meadestyle so if anyone cares to help me in real time that would be good too. Im on the tv here right now so its liveable, just not as clean as it should be....
****thanks in advance to anyone that can at least guide a young "grasshopper" the right direction!
:D
Discussion Starter · #6 ·
ttt...........here is my monitor info. If anyone can tell me how to set up power strip maybe that would help i dunno. I tried 1920 x 1080 @30hz and still get overscan........overscan and the graphics not being very sharp is my biggest problem. Ok here goes.......
Monitor
Manufacturer description.... SONY TV
Manufacturer................ Sony
Plug and Play ID............ SNY00F8
Serial number............... (n/a)
Manufacture date............ 2002
EDID revision............... 1.3
Display type and signal..... Digital
Sync input support.......... (n/a)
Screen size................. (n/a)
Power management............ Not supported
Color characteristics
Display gamma............... 2.20
Red chromaticity............ Rx 0.625 - Ry 0.340
Green chromaticity.......... Gx 0.280 - Gy 0.595
Blue chromaticity........... Bx 0.155 - By 0.070
White point (default)....... Wx 0.283 - Wy 0.298
Timing characteristics
VESA GTF support............ Not supported
Horizontal scan range....... 15-46kHz
Vertical scan range......... 59-61Hz
Video bandwidth............. 80MHz
Timing recommendation #1.... 1920x1080 at 30Hz
Modeline................ "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Timing recommendation #2.... 720x480 at 60Hz
Modeline................ "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
Standard timings supported
640 x 480 at 60Hz - IBM VGA
720 x 480 at 60Hz - Sony
1920 x 1080 at 30Hz - Sony
Raw EDID (1)
00: 00 FF FF FF FF FF FF 00 4D D9 F8 00 01 01 01 01
10: 00 0C 01 03 80 00 00 78 0A 0D C9 A0 57 47 98 27
20: 12 48 4C 20 00 00 01 01 01 01 01 01 01 01 01 01
30: 01 01 01 01 01 01 01 1D 80 18 71 1C 16 20 58 2C
40: 25 00 00 00 00 00 00 9E 8C 0A D0 8A 20 E0 2D 10
50: 10 3E 96 00 00 00 00 00 00 18 00 00 00 FC 00 53
60: 4F 4E 59 20 54 56 0A 20 20 20 20 20 00 00 00 FD
70: 00 3B 3D 0F 2E 08 00 0A 20 20 20 20 20 20 01 02
Display adapter
Adapter description......... NVIDIA GeForce4 Ti 4400
Adapter device ID........... 0x025110DE
Display settings............ 848x480, 32bpp
User/computer information
Registered user name........ na
Registered organization..... home
Network user name........... dad
Network computer name....... HOME-HWI50KOV8Z
Windows version ............ Windows XP
Windows build .............. 5.01.2600
Installation date .......... 1/18/2103 4:34:56 AM
While I don't have your set, from reading other posts, 1080 isn't very good for the PC Desktop, but fine for DVD watching. If you want to go with 1080, you might look at Karnis's sticky thread at the top (even if you are not using an ATI Radeon). Another resolution to try is 540p.
1 - 8 of 8 Posts
Status
