So currently running off an old PSU (source will later be invertable from PSU to deepcycle leisure camping battery which could also be charged using the PSU - later plans to make this fully mobile/portable for camping)
i know very little about this stuff ..you guys are the experts i hope lol
AMP is 2channel with 100w 8ohm per channel. so im thinking my 4ohm 200w speaker nad my 4ohm 200w sub will blow the amp quickly if volume is too hifg? i notice it heats up once i put the volume too high so im thinking it will eventually blow after low volume/mild use anyway (prolonging blowing the amp)
here is a diagram.. basically what do i need to fix this, change speakers?.. change the amp? and do i need a crossover if so which type? passive? how to i wire the passive crossover to the speakers from the amp also.??
