Ok, guys. I've been red eyed and w/o sleep for the last couple of days reading through about 15 million pages of the AVS forum..
Still don't know much, but more than I did two days ago.
I'm in the position right now of adding on to our house. This started out as a nice 1,500 square foot garage.
It evolved into a garage, with a 2,000 square foot basement. (and of course what good is a basement w/o a tunnel connecting it to my house) you get the picture.
Anyway, I have the opportunity to plan and build my theater room from scratch.
The room size I'm planning on right now is 18 x 28 x 9 (could be 20 x 28 if I see a reason to do it) The room will be completely encased by concrete, so I know this will pose some accoustical challenges..
What some things that you all wish you could of or should have done from the beginning but didn't.
I'm also looking for cost ranges..
After the box is done, I'm planning on spending about 50k on room construction and AV equipment. Where would this fall in the "quality" catagory.
Thanks for the help....
