Status
Not open for further replies.
1 - 2 of 2 Posts
I'm working through all the different options to determine what I need to build an HTPC. The breadth and variety of options is sometimes staggering.
My goals are:
- Playback of archived DVDs
- Timeshifting analog and digital cable
- Live viewing of Analog and digital cable
My current hardware:
- Hitachi 57s500 HDTV
- WinTV PVR-250 (this will go into a new PC that will be the HTPC)
Software:
- SageTV for TV recording/viewing
- MyHTPC for overall management
- Zoomplayer for DVD playback
- Dscalar? Not exactly sure where this fits in the process
Wiring:
- Based on reading a number of posts I'm planning on splitting the cable signal x3.
1. Analog feed to Hitachi
2. Analog feed to Cable input on PVR-250
3. Digital feed to Cable Box. Cable box outputs are:
- Digital HD output to Hitachi
- Digital SD output to component input on PVR-250
Now, comes the question (finally): What are my best options for connecting the HTPC to the Hitachi with the maximum PQ?
I don't plan on having a monitor on the HTPC, so the TV will be the primary display. Therefore, the desktop (or MyHTPC) will display on the TV like it was a huge computer monitor. I'm assuming setting up recordings through Sage will be done just like on a PC, as well as viewing live, recorded material.
So, I'm thinking that I just need a video card that can use the DVI port to connect to on the Hitachi. Will any VGA output do, or do I need a selected TV-out card to drive the HDTV?
Ray.
Discussion Starter · #2 ·
Here is a schematic for what I'm thinking about.
1 - 2 of 2 Posts
Status
